Re: Overdrive Off vs. Tow/Haul
This is how I used to drive my old 1996 E150 van with 300 straight six.
I can't comment on the effect on ATF temperature
As one of the first Econoline torqshift temperature monitors, allow me to say: I havn't noticed a temperature difference between towing and unloaded at highway speeds. I believe I recall reading something that says that the torque converter stays locked in all gears higher than fourth (of six). So going back between OD off and OD on doesn't unlock the torque converter, and an unlocked torque converter is where 80% of the heat is generated. When you take it out of overdrive, there is an additional planetary set spinning, so there will be an incremental additional amount of heat generated. But nothing like going stoplight to stoplight, which heats it up quickly unloaded and even faster with a trailer.
Now I need a trans temp guage. I know that Autometer makes one. Where on the transmission does it get installed?
Click my pictures, below, to see what you'll be up against. There is also a thread on this topic here and here.
"Nothing in life is so exhilarating as to be shot at without result." - Sir Winston Churchill
May your road stay clear & dry, may your fuel never gel, and may you never be outsmarted by your idiot lights.
2002 F-250 XLT SC LB 4x4 7.3PSD 6-Sp 3.73 L-S, Snugtop Snuglid Tonneau, 235/85 MC HTRs, <span style="color: red"> DPTuner F5</span> AFE Stg II, Turbo LifeSaver, MAP BRV, Autometer Cobalts, Magnaflow 4", WW, TAG, AIH del, CCV, AirDog, In-tank, Harpoon, HPX, ITP fuel sys, LL8 del, 203*, Oilguard & SP Diesel bypass filtration, ART rotors, PFC pads, Heater Core Ctl Valve, Bilsteins, Velvet Ride Shackles, South Bend Clutch, <span style="color: green">21.27 mpg</span>
2004 <span style="color: red">E</span>-350 XLT Wagon 6.0PSD 3.55 L-S TDM EZ-Entry 11 pass., AIC, custom MBRP 4" w/dual Aeroturbines, Airdog, harpoon, Overhead Cobalts
Pictures . . . Parts Links
