Diesel Forum - TheDieselStop.com - View Single Post - Turbo failed while towing
Old 05-05-2005, 05:51 PM   #2 (permalink)
dt_diesel
Re: Turbo failed while towing
Sounds like and electronic glitch, possibly that set a code. If you cycled the ignition key (Key off, key on) then restarted and it was okay, you likely had a fault that set a code. Ask your dealer to pull codes and check for "endplay" in the turbo itself. Likey electronic, not the turbo itself.
dt_diesel is offline   Reply With Quote
