Diesel Forum - TheDieselStop.com - View Single Post - 05 Turbo? noise
Thread: 05 Turbo? noise
Old 05-08-2005, 09:28 PM   #2 (permalink)
RaulDog
Re: 05 Turbo? noise
Sounds exactly like your turbo is over boosting because of being in a bind and the sound you are hearing is the excess boost releasing out your intake which is normal to sound like that but if it is stock (no chip) your turbo should not over boost. May have issue. The down shifting will eliminate problem because of higher rpms. Hope this helps.
2004 F-250 Lariat 6.0 4x4 CC Short Bed ,05 front end conversion, 05 flares ,4in. lift, 305/55/20 Nitto Terra Grapplers on 20x12 Weld Cheyennes, MBRP 3.5 DP 4 out to 6in. Silverline tip, SCT tuner, Quadzilla Monster intake KandN filter and camoed out!
RaulDog is offline   Reply With Quote
