Re: Problems with 05 Tow Command, IBC, torque shift?
if the owner can duplicate the problem that sure helps
Key point there! If you can make the truck "do it" then ask for a technician to go for a little ride with you, make it happen and point out what it is you are concerned about. When the truck does not misbehave on your road test then you might not get so annoyed with the tech or dealer - it's just not cut and dry sometimes.
Ford Master Diesel Technician
Diesel Technician Society
