Diesel Forum - TheDieselStop.com - View Single Post - Tow Command avail. with auto and not manual??
Old 05-08-2005, 12:23 PM   #2 (permalink)
unmguy2000
Re: Tow Command avail. with auto and not manual??
I have owned both manual and auto's since '87 model year. Ford has consistently over the years rated the auto's with a higher GCWR. IMO I believe this is due to the amount of slipping of the clutch to take off with higher loads. I know that when I was pulling a big 5er with my '88, I would occasionally get a bit of clutch smell when backing my 5er up a 6% grade driveway. This, however, was with my old 7.3L IDI truck and a 5 speed manual.
With the 6.0 and lower torque off idle, I already need to slip a clutch MUCH more than I would have ever done in the past. Once I get a big load on it, I can see why maybe Ford would derate the manual. However, the 6 speed with the very low starting gear would help. I just haven't pulled anything over 7k lbs with this truck yet.
Robert
2008 F350 XLT CC DRW 4x4, 6.4, Auto, 4.10, Manual Transfer case, Supplemental Heat, Wide Track Front Axle, Sirius.
1996 Newmar Dutchstar, 8.3L Cummins 6CTA, MD3060 Allison
** SOLD with 80,300 miles ** 2003.25 (Feb. 14, 2003 build) F350 Crew Cab 4x4 XLT, 6.0
unmguy2000 is online now   Reply With Quote
