Re: Problems with 2004 F350 Turbo
Get used to it, it will happen when you least expect it you need to take apart and clean the inside of the hose will some sort of carb cleaner or laquer thinner and reinstall The last time mine did it drove right up to dealers front door and they took one off an 05 which by the way was finally improved it was stapled to the hose itself eliminating one way of coming off it can still slide off the tube if not cleaned properly when reinstalled I had ordered a new and improved hose that I was told updated my existing 04 one and gave to the dealer for the one they took off the 05 and it was just like my 04 old one. There are better ones on the 05 get one of those if you can.
08 LTZ CC D/A 4X4 Dually
