4X4 Switch
The other day I turned my switch for 4*4 and it did not kick in. The indicator light did not light up either. I tried again did not work again. Then I turned the ignition off and restarted the motor and everthing was back to normal. I have switched it in and out several times since then, no problem.
I am curious have any of you had this problem and should I worry about this. Any help will be appreciated.
Dave
2005 psd 4*4
