Diesel Forum - TheDieselStop.com - View Single Post - Air Filter Quesiton
Old 05-15-2005, 08:50 PM   #12 (permalink)
GrampyJim
Banned
Re: Air Filter Quesiton
Once more, from the top.... about 5 minutes to R&R air filter.
Undo the clips and remove them.... you will lose one. Lift up on the clean air bell and pull it towards the rear. Lift the filter from the grommets ( a sharp tug usually does it) and position the spot for the tangs inside the clean air bell.
Lift up on the dirty air bell and, tipping the rear of the filter up, position the spot for the tangs inside the dirty air bell. Lift the filter up and out... reverse the process for installation. The only tool I use is a little screwdriver to pop the clips out.
It's real easy to make this job a lot tougher than it needs to be.
GrampyJim is offline   Reply With Quote
