Re: 96 psd oil dipstick through pan
Oh man oh man.....
That should say it all!
The part is aluminum and the other half must be inside the oil pan.
You may get lucky and fish it (and the oring) out with a stiff piece of wire, but thats only half the battle, you have to get a new one in there! Some have done it with needle nose vice grips, other wise, the un thinkable... you have to pull the egine and drop the pan to reinstall the part. I guess one other thought, cut a hole in the bottom of the oil pan, get the old parts out, put in new and weld a patch back on. I dunno know, real tough situation!
Best of luck to you, your gonna need it!
Rick H...
Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club
Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
