Diesel Forum - TheDieselStop.com - View Single Post - 96 psd oil dipstick through pan
Old 05-23-2005, 11:49 AM   #12 (permalink)
BellyHead
Re: 96 psd oil dipstick through pan
Your new o-ring is going to be much smaller than the one you remove. But after a day, and a little heat, your new o-ring will be the same size as the old. It swells pretty quick.
I had to remove mine a day later to reposition, it didn't work well because is was so swollen. I had to use silicone also. Mine still has a small leak and I can tighten the nut every now and then. I'll have to re-silicone when I run out of thread.
Get some vice-grips on the inside piece before you loose it.
-Shanon
'96 4X4 CC/ShortBed F-250, Hypermax Downpipe, Four" exhaust, ISSPRO EV Gauges in Rockin S Pod, Bilsteins, Hx Crossover, Open Air Element, Bill's chip (now with TWildman burns), BTS trans, <font color="red">Baby Swamps</font>, Gentex mirror with temp/compass, and Dana 60. My Photos
BellyHead is offline   Reply With Quote
