Diesel Forum - TheDieselStop.com - View Single Post - EBPV used as Exhaust Brake
Old 06-25-2005, 04:34 PM   #3 (permalink)
swh22
My Photos: (5)
Re: EBPV used as Exhaust Brake
Pretty sure you mean exhaust back pressure sensor, not the map sensor. I didn't have that problem, probably because my exhaust back pressure sensor was totally plugged up with soot and wasn't reading anything anyway. At least you know yours is working [img]/ubbthreads/images/graemlins/wink.gif[/img] You can buy or make a resistor to replace the sensor and trick the computer into seeing 10 or 15 pounds of backpressure all the time. Other than that, not sure what you can do.
Truck: '97 F250 PSD , ext. cab, shortbed, 5-speed, 4wd, 4.10L
Upgrades: BDP Stage I's, Stealth HPOP, BB Turbo with 1.0 wastegated housing, 6 pos DP Tuner chip, SBC OFE, dual SD fuel pumps, traction bars, US Gear OD, MAP regulator, SP Dongle, downpipe, extra 45 gal fuel tank, EGT-boost-TIP gauges, bilsteins, TYMAR, no cat, 3.5" flowmaster into 4" exhaust, gutted EBPV, XM SKYFi2, cab lights, BFG AT 285/75/16, Autoenginuity, 169k on 5/10/06
Coming soon: 6.0 Intercooler
Dyno'd 298/575, 296/582 before Stealth and Turbo
swh22 is offline   Reply With Quote
