Diesel Forum - TheDieselStop.com - View Single Post - blown fuse #17
Thread: blown fuse #17
Old 07-11-2005, 11:38 PM   #4 (permalink)
Equineguy
My Photos: (21)
Re: blown fuse #17
According to my tech manual, #17 is a 10amp - 'Trans control indicator lamp and switch, brake fluid level switch, warning chime, diesel warning lamps display, fuel water switch, low vacuum warning switch, instrument cluster, switch lamps'
The engine compartment fuse box #17 is 50amp 'Generator charge indicator, instrument cluster ( references fuses 2,3,6,11,17 and maxi fuse 22 ) also, circuit breaker 14.
Thats about the extent of my knowledge --> copy and paste... eh ehh ehh
-1997 F350 XLT crew cab 4x4 with big steel Gage RanchHand bumpers, Tymar intake ( 1-2 mpg improvement ) , 3" to 4" DP 4" exhaust exiting in front of rear wheel w/5" SS downtip. DIY AIC control ( AIC on Ebay now ), Premium Warn Manual hubs just installed, and Alpine 6 1/2 - 6x8 component speaker system. TW 6 pos chipset.
-1979 F250 4x4 with 33", gas 302. All farm truck, more rust than truck, more spunk than Chevy.
-1970 Ford 3400 tractor, 3cyl diesel with a cracked loader ( no longer cracked, I learned how to weld, yeeeaahhh! )
-1983 White/Herc 6cyl deisel 65kw genset that provides 180A to the house PRN.
Equineguy is offline   Reply With Quote
