Re: Electric over Hydrolic Brakes & ITBC
The reason that Ford says it does not work is because the ITBC sends out a pulse periodically to test if the brake circuit is complete (i.e. the trailer brakes are connected and working). With electric/hydraulic trailer brakes, this signal is enought to activate the hydraulic pump, resulting in premature pump wear.
Newer electric/hydraulic brakes systems are designed to work with the newer TBC that send check signals and ignore the pulses. Chances are if the brake system was made in the last year, it will work fine with the ITBC, but check with the system manufacturer.
Cheers,
Tom
that is funny brakesmart sends out a pulse to check the brakes and it works great with electrolic brakes.
[/ QUOTE ]It depends on the pump/actuator. Some pumps will not tolerate that and they had to add programming/menu options to turn that "feature" off so it would not damage the pump/brakes.
2002 F350 Lariat CC 4x4 Auto 4.10 DRW, DP-Tuner F5 live tuned stock, quiet, 40dd, 40, 60, 80 tow, 80e and 120r, B&W GN, BrakeSmart, 'pooned tank, tank and pre-pump mods, 2µ Dahl 100 filter, regulated return, BTS dual HPOP, AC singles with EDM 34 lpm nozzles, AIS, H2e, Spearco 6.0 IC, Hypermax 3.5" dp--> MBRP 4" 304SS exhaust, BTS tranny, 203º T-stat, Chevron ELC, coolant filter, Oilguard bypass with Schaeffer 9000, WranglerNW 200 amp alternator & Optima group 31 batteries, Nippon-Denso starter, SPA gauges, SteveRacer mods, Hella 80/100W 9007s, Hella Micro DE foglights, 1000FF driving lights, 220W backup lights, Stancor contactor, Michelin XPS Traction tires, X-Springs, Bilstein shox, custom bumpers but otherwise stock. Nov 30 '99 build engine with 16 K miles, Fluidampr, Comp Cam 910 springs, Melling LPOP and ARP headstuds.
