It has been too many years since my Lowbed driving days. I hope I remember this correctly.
8'6" is the max you can be in CA without oversize load signs and permits.
Depending on the roads you are on, I believe you need at least 1 pilot car after 12' wide (sometimes 2).
If I remember correctly you need a CHP escort (+ pilot cars) after 14'6" wide. (again road dependant).
Keep in mind, it has been many years. Hopefully someone will come along with more current info and correct my bad memory. This should get you started though.
You don't need a permit - other than normal license plates - for any RV (or any other vehicle) up to 8' 6" (102") wide.
If your RV is more than 102" wide, you have an oddball that requires a permit. /ubbthreads/images/graemlins/crazy.gif
Here is a summary of the Texas rules for width, length and weight of vehicles. Click here.
In Texas it's 102" wide without a permit. Most "luxury" RV trailers and motorhomes are about 102" wide. For example, a Newmar Dutch Star diesel pusher is 101.5" wide, and a Newmar Kountry Aire 5er is 101" wide. So I suspect all other states would have at least 102" max width.
Actually looking for info. on max width for boat trailers with permit.
Wider than max without a permit is known issue...trying to determine what permit will allow without banners, guide cars, etc...
That is probably going to be on a road by road basis. I-5 is going to be less strict on number of pilot cars, days of travel, etc. Than say Hwy 80, 50, etc.
You will have to have oversize signs and a permits on anything over 8'6".
Try Hauling Campers Commercialy, you need over with permits for several states, with the 8' 6" trailer, plus the awning, plus the exhaust on toy haulers your to wide, Wy has a annual permit it is 150 dollars, Colorado has one also, and there are several more that have them also.
Also they get you on the cgvw, truck 9900 lbs, trailer up to 17,000 lbs gvw, and you better have tags that cover both. In this case put you over 26,00- gcvh and you will need cdl with combination.
So there is a big diference in hauling commercialy and privately with the same rig!
AS usualy..the government web site is in code..... anybody know what you can legally tow with a "permit" for daily RV use?
a
I would HIGHLY suggest that anybody and everybody that hauls an RV or any type of pull behind trailer go get themselves a Rand McNally "Motor Carriers Road Atlas" Make sure you get a current version, as roads and laws change much faster than what you think. You guys/gals will find an absolute ton of information in one of these Guides. They list legal load width, lengths, heights, bridge tables, etc... For each and every state including Alaska. Plus lots and lots of other great stuff for going down the road. I cant tell you how many times I have grabbed my map to see just how far the next rest area is /ubbthreads/images/graemlins/biggrin.gif
They come laminated and last for several years. Generally the cost is around $50, but if you look around a while you'll find them on sale for close to half. Every major truck stop in the US carries them.
Back when I drove a truck over the road I would take advantage of the laminated pages with a dry erase marker. I would map my trip out by drawing a dry erase marker over the route I would take. This becomes especially useful when going through an unfamiliar big city.
Two versions of this book exist. One if about half as thick and is just regular paper, and contains only about half the info. The other is fairly thick and has the laminated pages.
Link I have seen them on eBay/Half.com for under $20. ISBN 0528900625 They also have a large print version.
Don't think there is a maximum width "with" a permit.
There is for most loads in Texas. However, they will probably still issue the permit provided you complete "route and traffic studies" that prove the item can be moved on that route without banging into anything or disrupting traffic more than an acceptable amount. For example, they move huge oil-field drilling platforms that can barely squeeze through between the telephone poles. But often at 3 a.m. when traffic is nil.
From the link I posted earlier in this thread:
Texas Legal Size and Weight Limits
The State of Texas has established legal size and weight limits for vehicles and the loads when operating on state-maintained roads and bridges. These dimensions include:
Width Limits
Width is measured from the outside points of the widest extremities, excluding safety devices.
<font class="small">Code:</font><hr /><pre>
Explanation Measurement
Legal width limit 8’6" (102")
Maximum width permitted on holidays 14’, except for manufactured housing
Maximum width permitted on controlled access highways (Interstate Highway System) 16’, except for manufactured housing
Maximum width permitted without route and traffic studies and certification by
applicant on file 20’
Maximum width permitted for new houses 34’
Maximum width permitted for existing houses 40'
Maximum width permitted for new tanks 34’
Maximum width permitted for existing tanks 40'
Maximum width permitted for portable buildings No limit
Maximum width for manufactured housing No limit
</pre><hr />
[*] There are special requirements for manufactured housing
Thanks for all the info...but guess I need to clarify.
I know Cali. has a "permit" for loads over 8'6" that you can haul oversize boats without pilot cars and wide load signs as a private hauler for personal use.
The permit is something like 150 per year.... just trying to find the code that describes the permit and what the maximum width is under this permit?
Why ask us Go to the caltrans site and look it up Yourself. Sence you dont believe US.
The only reason to go to the "Caltrans site" would be if he wants to read about freeway construction /ubbthreads/images/graemlins/shrug.gif
.. and i'm sure he "would believe US" if anyone had actually been able to answer his specific question on width of boat trailer,... which will be found somewhere on the DMV website.
Out of curiosity, how wide is your trailer when loaded?
The reason I came here is because the DMV website is very unclear on this subject and I was unable to find the right part of the code that described what I am looking for.
They've tried to make the site "user friendly" which makes it impossible to find specific parts of code.
I'm trying to determine if the max with permit without signs and pilot cars is 10' or 11' etc.....
No trailer yet....this will impact my decision. I think it is 10' because you can find many boats built at 9'6".
Actually CA DOT sets some of the regs on width, height, and weight etc. DMV does the licensing aspects of same and regulates some aspects.
Here is the site that has all of the CA Government Codes:
You will want to search the "Vehicle Code" first and if you can't find it there, search "Streets and Highway Codes". Check the box by each, set the "Limit" to "All" and enter your search parameters. Happy looking.
[quote ] Out of curiosity, how wide is your trailer when loaded?
Sence It had my name at the top I guess you are talking about me. I haul for a company and some of the aircondion duck work is oversized. Max has been 20foot but we are bonded for oversize and have all the permits. took a tank to El Paso 16 wide 19 high and hit every backwood road from fortworth to elpaso. changed 8 highways in a mile in one county, Just toget around one underpass.I do have a 45 foot boat in the gulf down in Port Isebel. and it gets trailered when I go to washington state but it is only 10 1/2 wide.
The thing I posted about boats is misleading. Over 8'6" you need an oversized permit. The link I posted is for getting a Variance, and I believe thats anything over 14' wide. Hopefully this doesn't apply to you.
MAX is 102" wide in Kali. That includes your awnings boys! Most with 102" RV's are illegal because the awning puts you over the limit.
You're legal as long as it's your RV, if you're hauling it for someone and getting paid for it, you are conducting interstate commerce and are overwidth.
Read the post I posted before awnings are not figured for over width in california even if you are hauling and getting paid for it. If that was true then every truck on the road (big truck that is )would have to get a permit because its mirrors stick out past a 102 trailer.
Incorrect again, mirrors are exempt as they are necessary safety equipment and have to be positioned wide enough to see around 102" trailers. Order a FMCSA Regulation book if you want to learn more about commercial hauling, and yes, you are overwidth if you are delivering the motorhome w/awnings over 102" IN ALL STATES. Just because they don't all inforce the law equally doesn't mean you're not breaking it.
Related Threads
The Diesel Stop
2.6M posts
211K members
Since 1999
