Diesel Forum - TheDieselStop.com - View Single Post - OK...Whats the deal with this UVC wiring?
Old 08-31-2005, 02:34 PM   #4 (permalink)
streetdoc432
streetdoc432's Avatar
Re: OK...Whats the deal with this UVC wiring?
The only way to check is to remove your valve cover...Do you know which side is messing up? Find someone with a IDM code reader, If it says #_ cylinder circuit open..even number cylinders are on the drivers side, odd # cylinders on the passenger side. Once you figure that part out, lay some carpet or padding across your engine, climb up on top of it, and make yourself comfortable. Take off your intercooler tubes and whatever else is blocking your access to the valve cover. Once you get the valve cover out of the way, the plug is right there in front of you, you can't miss it, it may be covered in oil, but it is really kind of simple to replace. R & R only took me about an hour and a half.
2003 Excursion Limited 4x4 7.3 PSD. Custom "Western Hauler" conversion. On board Firestone air bags. 4" stainless steel MagnaFlow exhaust with muffler delete, AFE Stage 2 intake, AutoMeter Ultralite 3 gauge pillar pod, DRV++,AIH plug,18K mod w/TAS, Superchips 1705 tuner,Zoodad mod,Transgo stage 2 shift kit, Kenwood 1000watt stereo-DVD with three screens. 6" Pro-Comp lift, 20" black XD Hoss wheels with 35" Nitto Terra Grappolers.
streetdoc432 is offline   Reply With Quote
