Re: OK...Whats the deal with this UVC wiring?
My recommendation is to get replacement harnesses. The connectors themselves get brittle and will no longer hold them tight to the VC gasket. You may even break the connector trying to put the clips on (don't ask how I know this [img]/ubbthreads/images/graemlins/crazy.gif[/img]).
Retainer (Under Valve Cover Harness clips)
2C3Z-14A163-AB
Int’l 1844193C91
Wiring Harness, Injectors & glow plugs
F81Z-9D930-AB $50.15 (online ford parts place price)
Int’l 1830844C93 ~$25
One of the guys hot-glued the connector to the VC (I think it was the outside one, but if cleaned up well, that might work on the inside one also).
Hope that helps
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
