Diesel Forum - TheDieselStop.com - View Single Post - OK...Whats the deal with this UVC wiring?
Old 08-31-2005, 05:38 PM   #7 (permalink)
JimTJr
JimTJr's Avatar
My Photos: (20)
Re: OK...Whats the deal with this UVC wiring?
There is ONE Main connector on the Under valve cover (UVC) harness...it has 8 other connectors on it...4 to the injectors and 4 to the glow plugs. The gasket has two connecting points on it...inside the VC and outside,,the one you can see in the valley of the motor..(If you lean over and look hard..lol) Then the engine harness connects to the gasket. I would check allllll connections of course. Look for burnt pins..melted plastic, ect...
Neither one of the valve covers are that hard to remove,,the passenger side is more intimidating,,,but not that bad really.
Jim T.*48* SLAPS Co-Founder, 30.8 yrs RETIRED UAW 6/01/06, Now an ART (Specialists Flight Chief) with the USAFR 414th MXS Seymour Johnson AFB. My pics! '03 Dually pics!, New truck, 2011 F-350 SRW LB CC. White Platinum Lariat! 4x4
JimTJr is offline   Reply With Quote
