Re: OK...Whats the deal with this UVC wiring?
OK stupid question but... Would an IDM code throw an SES light? Because so far we've never gotten a light but everything I've read of other people's problems points to the UVC stuff.
An unplugged injector WILL light the SES and throw the P1316 and P127X codes. Not sure if an intermittent problem would do that, but it will still throw the code. Maybe the SES isn't on long enough for you to notice it.
Also checked with local International dealer..
Clip kit: $8.22 (3)
Wiring harness $18.12 /each
Not too bad
Good prices - wish we could do that good up here (the good ol' Alaska Gouge [img]/ubbthreads/images/graemlins/frown.gif[/img])
So if you have to pull it apart to "really" check it out, is there another connector on the inside??
What Jim said.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
