Re: OK...Whats the deal with this UVC wiring?
Well, thanks to the help I went and changed both harnesses tonight, not that big of a deal if you just take your time like anything else. Runs better so I suspect that the old stuff had seen better days. So far no more dropping idle and noticable smoother.
Still shakes like hell right about 38mph when it hits lock up!! Argh. Tranny is smooth in all other gears...Torque converter time?
2000 F-350 Centurion CC/DRW/XLT/PSD/6spd/ESOF/4.10LS Wedgewood Blue/WD Chip/4 Straight Pipe/WD Gauges/Custom Frontend/J&J Grille, Boards & R-Bumper/Homemade EBV Brake, AIC & Ignition Bypass/Warn 12k Winch
99.0 F-350 SC/DRW/XLT/PSD/Auto/2wd Tourmaline Metallic/Stock for now!
