Diesel Forum - TheDieselStop.com - View Single Post - OK...Whats the deal with this UVC wiring?
Old 09-02-2005, 02:23 AM   #12 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: OK...Whats the deal with this UVC wiring?
Anyone have the International part numbers for the harness and/or pigtails from the outside of the valve cover to the 40 pin connector?
VC connector to 40 pin (actually 42 pin) is the whole engine harness. Many $$$ [img]/ubbthreads/images/graemlins/eek.gif[/img]
Try a PM to Dave1957. He gave me some numbers for other repair pigtails, but not the VC outside connector one. Maybe he can track it down for you.
Hard or no-start? Check Here
