Re: Vibration and weirdness.. Lost!
Check the main wiring harness for rubbed spots. A likely spot is where it crosses the driver's side valve cover. Some of the guys have found injector circuits shorting out there. Don't remember if they got an SES light or not though.
Also check the harness connectors for proper fit of the pins. If some have gotten loose, they might cause your symptoms.
On the other hand, those things should have set a code. What are you using to read codes? Not all readers work on the PSD.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
