Diesel Forum - TheDieselStop.com - View Single Post - Howto: 05-06 High Idle (AIC/SEIC/BCP)
Old 10-31-2005, 04:35 PM   #4 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Howto: 05-06 High Idle (AIC/SEIC/BCP)
Stu,
I'm going to make this a sticky post for a while. ON EDIT: I guess I don't have the stroke to do this. It said it was done, but didn't actually work.
I'm also going to recommend that you put this together as an article for posting with others on the TDS Home Page. Please consider writing this up and submitting it to Dave Bey so he can post it.
Thanks for your contribution
Kevin
Hard or no-start? Check Here
