Diesel Forum - TheDieselStop.com - View Single Post - Howto: 05-06 High Idle (AIC/SEIC/BCP)
Old 11-04-2005, 08:32 PM   #17 (permalink)
mike12150
Re: Howto: 05-06 High Idle (AIC/SEIC/BCP)
Well I followed the instructions provided at the top of this post and it works great. I wired the Aux switch 4 to the BCP (purple with green stripe) wire and the Aux 3 to the (orange) PTO wire. I took it one step further and wired in a 10K OHM variable resistor for the pto system. Now when I turn on the 4 switch the engine goes to 1200 and so far stays there. If I turn on the 3 switch I can dial any RPM from 1200 to 2400 and it seems to stay exactly at what I set it too. I already had all the parts and the whole thing took under an hour. I also found some good info about what wires to use at this link:https://www.fleet.ford.com/truckbbas/non-html/Q108.pdf
Thanks StuartV!
2005 F350 XL Crew Cab, 4X4, Long bed, 6.0PSD, 6-speed manual, dual alt. camp package, snowplow prep
2005 Jetta TDI (girlfriends car)
mike12150 is offline   Reply With Quote
