Diesel Forum - TheDieselStop.com - View Single Post - Howto: 05-06 High Idle (AIC/SEIC/BCP)
Old 11-07-2005, 03:52 AM   #21 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Howto: 05-06 High Idle (AIC/SEIC/BCP)
We have a 99 7.3 in an E350 at work, lotsa of electronics and also the need for A/C. I have found the bundle under the hood (which is labled differently) however, haven't had the time to check around the fuse box yet.
The customer access wires on the 99-2003 7.3's & maybe 03-04 6.0's are just dead wires thru the firewall. Just as a way to get wires thru the firewall without drilling holes. You'll need to get an AIC or make one yourself to bump the idle speed up on that van. Check in the feature articles of TDS for a how-to.
Hard or no-start? Check Here
