Re: Howto: 05-06 High Idle (AIC/SEIC/BCP)
It's not that you need to purchase it so much as the aftermarket people NEED to sell more gadgets. The Aftermarket throttle commanders and such were necessary on the 7.3's and now with full electronic throttle it's a DIY project. I believe any vehicle or heavy truck or equipment with an electronic throtle can do this. The accelerator pedal on electronicly controlled engines is nothing more than a potentiometer telling the PCM to increase RPM when depressed. By knowing the voltages and right pin on the PCM you can make the engine do most anything you want.
06' F550 Field Service truck
