Diesel Forum - TheDieselStop.com - View Single Post - Hard/No Start? Check here first.
Old 12-17-2005, 05:30 PM   #11 (permalink)
Vindicator
Re: Hard/No Start? Check here first.
What if you have a CA truck and have the Glow Plug Controller instead of the Glow Plug Relay? How would I go about testing this thing? It has 2 pigtail plugs goin into it...Thanks!
'01 PSD 7.3L Excursion Limited EBM1, MPT81s, ORU dual shock hoops, King piggybacks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid 105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Dec 2010 ALMOST BACK ON THE ROAD!
Vindicator is offline
