Diesel Forum - TheDieselStop.com - View Single Post - Hard/No Start? Check here first.
Old 12-19-2005, 02:48 AM   #14 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Hard/No Start? Check here first.
They are tough little buggers, and hard to get to.
Push down on the lump on the center of the connector to release the hooks just to each side of that lump and at the same time use a small screwdriver to gently pry the connector apart at each end. Stick the screwdriver in at the joint where the seal is and twist.
Hope that helps. I'll be getting at mine in the next couple of days and will try to post a picture.
Hard or no-start? Check Here
klhansen is offline
