Re: Hard/No Start? Check here first.
You can just take your multimeter put the leads in the top of the connector. You don't even have to take the plug off.
If you're talking about sticking the multimeter lead down beside the wire going through the seal, I think I'd avoid doing that. Those seals are there to keep moisture out of the connectors. If you damage a seal, you may find that the terminals will get corroded, causing at best a bad connection, and at worst a toasted external connector.
I've been trying to find a source for the external connector, but haven't been successful. About the only other way to repair that is a $500 engine harness. [img]/ubbthreads/images/graemlins/eek.gif[/img]
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
