Re: Hard/No Start? Check here first.
Great write up! One quick comment, when my GPR went bad, it was intermittent.
I would turn the key on, wait to start, and try to start it. at first, once out of 10 times it wouldn't start right up, and I'd repeat the process.
Eventually, it wouldn't start no matter what.
Only reason I mention this, is using your great testing techniques, you might "luck in" and test it when it was working.
The 99 and up GPR is like 25 bucks at the local parts store, and the local parts store DOES stock them, and it takes under an hour to replace it.
Hint hint.
When in doubt, change it.
99.5 Superduty Crew 4x4 6 speed Smokewagon
Pizza cutter tires, Tymar, BTM, DP
If it don't run, chrome it.
