Re: Hard/No Start? Check here first.
Would it be possible to convert my Glow Plug Controller to the Glow Plug Relay setup? Dont they do the same thing???
'01 PSD 7.3L Excursion Limited EBM1, MPT81s, ORU dual shock hoops, King piggybacks all around, Magnaflow T304 system w/5" tip, FTVB w/50/50 mix regular Mercon/Mobil 1 in trans, Mobil 1 PS flush, Tri-pillar loaded w/Di PriCols (EGT,trans, boost), TS 4 pos. switch chip, ConFerr Rack, Cobra CB, TT/sig mirror conversion, 170 hi-amp alt, Hi Lift equipped, UltraDuty rearend cover w/Mobil 1 syn. w/OE friction modifier, Hutch/ITP intank mod, 2 Micron Dahl PrePump, FPR Jack shim mod@ 70psi, 203 deg T-stat & billet housing, Hawk pads, Centric rotors, Valvoline synthetic brake fluid  105.5k so far...
Recent mod: Dieselsite Coolant filter 4/21/05 @ 1100 @72 degs. F ambient temp ;P
Dec 2010 ALMOST BACK ON THE ROAD!
