Re: Hard/No Start? Check here first.
Would it be possible to convert my Glow Plug Controller to the Glow Plug Relay setup? Dont they do the same thing???
They do the same thing, but go about it a little differently.
If you could determine which wires to your GPC come from the PCM to activate it, you could probably rewire the engine harness to install a GPR instead, but I doubt it would be worth the effort.
I believe the solid state GPC may be a litte more robust than a GPR, not having contacts to arc when it disconnects.
Sorry I couldn't be more help.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
