Diesel Forum - TheDieselStop.com - View Single Post - Hard/No Start? Check here first.
Old 12-22-2005, 05:21 PM   #25 (permalink)
klhansen
klhansen's Avatar
My Photos: (169)
Re: Hard/No Start? Check here first.
Other times, Id put it in the on position in the morn and the batt. indicator on the dash would slowly go down to the 8 mark very erratically and then the stock headunit would flash on and off, as well as a bunch of clicking coming from the engine bay.
That sounds like you are having a battery issue. How old are they?
When the truck is warm, it wouldn't have the problem. I'm thinking the ECU is bypassing the warming of the GPs and thus bypassing the GPC? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Yes, the GPR (and presumably the GPC) is controlled by the PCM to only energize the GP's when the engine is cold. If the oil temp is over a certain value, the GP's won't even be turned on.
Hard or no-start? Check Here
klhansen is offline
