Diesel Forum - TheDieselStop.com - View Single Post - Hard/No Start? Check here first.
Old 12-28-2005, 03:59 PM   #38 (permalink)
kzelhart
Re: Hard/No Start? Check here first.
>>Will it still start in warm weather with a faulty GPR? Do they completely fail or get tempermental???
Depends on if it fails open or closed. If it fails open, yes it will. If, as in the case of mine, the control relay fries or shorts, you will blow the ignition fuse. A 30 amp on my 99 350, right column, bottom. Removing the hot control wire will allow you to keep the fuse in and start. Besure to tape the end of the control wire so it will not go to ground while you obtain a replacement.
kzelhart is offline
