Re: Hard/No Start? Check here first.
Do you plug it in? Are your GPs and Relay working well. Do you run Synth oil? Yes, there a lot of things here that should help you. If your truck starts fine the rest of the day, it's just sluggish. You should be able to track down the culprit using the stuff on this thread.
Good Luck.
