Re: Hard/No Start? Check here first.
IM HAVING THE GPR PROBLEM AND WAS WONDERING IF ANYONE CAN VERIFY WHAT THE STEALERSHIP JUST TOLD ME WAS ACCURATE....HE SAID MY TRUCK TAKES THE MORE EXPENSIVE SOLID STATE UNIT (03/2000 BUILD DATE) OR IF THE NAPA GPR 110 WILL WORK FOR ME...THANX IN ADVANCE [img]/ubbthreads/images/graemlins/shrug.gif[/img]
If you have 2 relays behind the fuel filter, then the GPR 110 or GPR 109 (much cheaper will work).
If you have only 1 relay and an aluminum box with cooling fins on it, then you have a Glow Plug Controller and will need to buy that, if it's truly the controller gone bad.
I think that the Excursions had the GP Controller instead of a GPR.
99.5 F250 PSD Supercab LB 4x4, ZF-6 w/SB Con OFE, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, DP 80 HP Econo PCM (classic version  ), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check Here
