Re: EDGE Platinum HOT JUICE CODE???
i told them i was not happy with the new box the tech put me through to an engineer he told me that the ejf-2000 was not as aggressive as the 1000 and it would not preform the same ,they reduced the power becauce of so many tranny problems.any way i ask him about the new platinum and he said it was the same program as the 2000 so it would not have the power as the 1000. he said you could upgrade it the hot juice it would have the same power as the 1000.
From my dyno testing this is exactly what I am seeing. I was dissappointed when I discovered that the Juice for all years (EJF-2000) was substantially less powerful than the original juice (EJF-1000). The injector pulse width was reduced. The Platinum is at the same power level as the (EJF-2000). The "hot" version makes the same power as the original juice which has always been one of the most powerful units out there but someone with the original juice wont see any more power with a "Hot" Platinum.
Tadd
Elite Diesel Custom Tuning www.elitedieseleng.com
tadd@elite-diesel.com
1-866-631-8518
Elite Diesel SCT Tuning for 6.0 and 7.3's with Cylinder Pressure Adjusted tunes, Programmers or 6-position chips, Custom 6.0 Injectors, 2 Stages of 6.0L Fuel Systems, H-11 Head Studs, Fire Ring Kits, Single and Compound Turbos for the 6.0L, Engine Internals
04 F350 XLT SPORT CC DRW
Elite Diesel SCT Tuner,AFE Stage 2, 345cc Injectors, 6" Stacks, S400 turbo. 701hp on #2
Look in the september issue of Diesel Power Mag.
Ford Senior Master Technician
