Diesel Forum - TheDieselStop.com - View Single Post - Winter Operation
Old 12-17-2005, 09:38 PM   #36 (permalink)
DENNY
Re: Winter Operation
AKVolDaddy
Hi
We missed you at the Alaska rally today. My advice on ATF is it belongs in the tranny not the fuel tank. There are several good Diesel fuel additives that are made to lube, clean and prevent gelling of the fuel. I would use one of them not ATF. The exhaust backpressure valve is what is causing the pssst pssst cycle at the high idle. It is making the motor work harder so it will warm quicker it is not the wastegate getting rid of boost. Keep an eye on the events and rally forums we will be haveing another one comming up.
DENNY
1999 F350 CC SRW LB 4X4 SIX SPEED.
DENNY is offline   Reply With Quote
