Diesel Forum - TheDieselStop.com - View Single Post - No Oil from Lube Pump Need Help
Old 12-05-2005, 09:39 AM   #2 (permalink)
dpugh
Re: No Oil from Lube Pump Need Help
could be cracked oil pump pickup tube.
jack the back of the truck up as high as you can
and refill the res. and see if it says running.
97 f-250 reg cab psd 4:10 gears e4od bone stock 162,000. only one GP relay and one alternator vac pump two sets of tires.
dpugh is offline   Reply With Quote
