Re: No Oil from Lube Pump Need Help
was looking at the oil path and looks like there are two paths for oil to reach the HP res. one right off the pump up through the front cover with a check valve. The other is off the main gallery above the check valve.
The bad thing is there is no way to indicate engine lube oil pressure. All the gauge tells you is you have presure in the HP Res. [img]/ubbthreads/images/graemlins/rolleyes.gif[/img] What are the berings getting? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
as an after thought; I so do not want to pull the engine out of this truck. That has just got to suck.
Paul H
OWNER
 2004 Ford F350 6.0L Dualie 214.000 miles with Edge Insight, Early Build 8/03 with 03 engine problem child
 1996 Ford F350 7.3L Dualie 337,000 Tony Wildman custom burn,5 inch stacks, good ole girl
FOKISD CLUB MEMBER
FOKISD CLUB SITE WEBMASTER
http://www.fokisd.org/FICM.html
My Pictures
