Diesel Forum - TheDieselStop.com - View Single Post - No Heat
Thread: No Heat
Old 12-21-2005, 11:36 AM   #12 (permalink)
CalWaterboy
My Photos: (6)
Re: No Heat
my coolant level is full. I have been filling it. Now that it is cold I fill it at about 1 gallon per month. Mine is a puker. I'm scared a head gasket is the problem. Would bad head gaskets cause this, maybe air pockets. I now that when head gaskets cause low coolant then no heat is an issue. My coolant isn't low???
I pulled the coolant return line off at the overflow bottle, from the egr cooler and I get a lot of air bubbles, maybe exhaust gases in this line. Maybe holes in the egr cooler causing puking and no heat?????
Try keeping coolant @ minimum level - may puke no more. Isn't there a chemical check for exhaust in coolant?
'04 Lariat 4X4 CC
CalWaterboy is offline   Reply With Quote
