Diesel Forum - TheDieselStop.com - View Single Post - No Heat
Thread: No Heat
Old 12-21-2005, 10:26 PM   #18 (permalink)
claytonr
Re: No Heat
you may also have air pockets in your system.if i remember correctly you need to fill system by removing plug in upper radiator tube to fill.my semi had same problem and i removed radiator cap and let the t-stat cycle a few times-problem fixed.having air in system mioght also cuase puking but you said you didnt start adding coolant till it got cold-sounds like a cold leak.wont leak after engine heats up but will after it cools.might check all connections or better yet take to dealer and have w2arranty fix it.
2003 X Limited 4WD 6.0,auto,55k mi. I'd buy another if FORD still made them.
1993 F150 4WD,5.8,auto,33s,315k mi.Never been stuck.YET!
New ride 1995 FRTLNR FLD120 Reman DD12.7 470hp,13spd,3.08 rears.Yeah I know,all the DD bashing I've done and I go and buy one.With the reman in it for $14,750 my mechanic said if I didn't buyit he would.
4 SALE 1993 FRTLNR coe N14 460hp,13spd,single axle,all aluminum wheels.
claytonr is offline   Reply With Quote
