Diesel Forum - TheDieselStop.com - View Single Post - No Heat
Thread: No Heat
Old 12-22-2005, 05:08 AM   #19 (permalink)
jrrepair1
Re: No Heat
Check the thermostat. Mine was doing the same thing. I didn't notice the loss of heat under low load conditions untill it got about 20 degrees and lower. I knew the rest of the system was good, and was stopping to check the temps of the engine with an infered thermometer. I also noticed ( on my truck anyways) that the temp guage would actually start to go back down if I was cruising, or idling. I swapped out the T-stat and it will heat me out of the cab without a problem. That is what fixed my problem anyways. Like usual the Ford dealers I talked to said they have never sold a T-stat for a 6.0L yet??!! Who knows.
2003 F-350 SD. 6.0L Powerstroke, Torqueshift, AEM Bruteforce intake / dryflow synthetic filter, MBRP 4" turbo back exhaust w/powertube, TS Performance 5X Downloader (usually at 100hp)
jrrepair1 is offline   Reply With Quote
