Diesel Forum - TheDieselStop.com - View Single Post - hydrogen fuel injection
Old 01-13-2006, 11:17 PM   #8 (permalink)
wanderer4x4
Re: hydrogen fuel injection
H2O - did anyone notice where the 'o' got to? ( couldnt find any reference on their website as to whats done with the oxygen molecule from the water) I'm wondering if its also introduced into the incoming air stream to give a more compelte burn ? (again - would that low of a volume be enough to notice ??)
probably not worth asking, but what would happen to the combustion pressures ( and hence power output) if WATER was introduced in controlled minute quantities? higher chamber pressures as it turns to steam? cooler egts? higher gas flows through the turbo? on gassers its used to control detonation problems...but the % is so low in this setup [img]/ubbthreads/images/graemlins/shrug.gif[/img]
c.
'52 S1 96" Land Rover MB 240TD conversion
wanderer4x4 is offline   Reply With Quote
