Re: Adding an intercooler
Jeff, I noticed your truck is 4x2. If you use a 6.0 intercooler you will have to first drop your sway bar 4" and use that to determine the mounting location for the intercooler. Check out the pics in my sig-I also built my own brackets and pipes out of some 6.0 pipes and a L.side SD pipe. I used an early '99 y-pipe.
Sniperonhigh are you say that the 7.3L IC is a little smaller and you don't have to drop the sway bar down?
Todd
AKA Toad
1995 Ford F250 7.3L, auto stock 390,000mi, filler neck Mod, 3" DP with test pipe (no cat!), Fumoto oil drain valve, BDP Stage I Injectors, Tymar Intake, DB Electrical High Torque Starter
1965 Ford Mustang Fastback 289 4bbl 75,000mi
1988 Honda CRX Si 1.6L stock
1988 Honda CRX 1.5L stock
1990 Honda CRX 1.5L stock
1991 Honda CRX 1.5L stock
1998 Kawasaki Vulcan 1500 Classic
1981 Honda GL500
1995 F350 7.3L Parts Truck
