Diesel Forum - TheDieselStop.com - View Single Post - How many WVO miles... post em up!
Old 01-21-2006, 09:51 AM   #5 (permalink)
350 long rod
My Photos: (17)
Re: How many WVO miles... post em up!
I have around 12k miles on veggi.I converted a year ago most of those miles are towing a 5th wheel.Had filter problems at first but that was due to condensation in my tank. I installed trapps on the tank and on the filter and raised the pick up point in the tank also I now keep the tank full letting it get about half empty then fill it back up.Before I was running it at half a tank or less this allowed to much volume for air so when it cooled down ot would pull in so much of our moist air I live in the PNW it has rained here for the last 30 days almost solid and even in the summer we have pertty high humidity. I just changed my veggi filter it had 10k on it vacum was starting to run at 5 in under load clean it runs at 2 to 3.
350 Long Rod
89 F350 4x4 CC ,97 5.9 Cummins, Fuel plate ground to a 100 profile,boost set to 30 lbs 5spd 31/2 exh no mufler. boost&pyro gauge.2500 lb frame mount overloads.power stroke intercooler,Valaire clutch.pulling 33ft 5th whl, 2000 Tahoe transporter.Hauling Banshees one with a long rod motor and my own porting,T-3s single carb the other stock port with pipes.
350 long rod is offline   Reply With Quote
