Re: DOT feedback Re: weight, CDL, and registration
[/ QUOTE ]I think someone better read their post and the dmv. If the trailer is under 10000 you need a class B if the trailer is over 10000 then you need a class A CDL. You stated my truck 11400, trailer 12000. so is 12000 greater than or less than 10000.Is 10400 greater than 10000 or less than. this mew math is killin me.
If the trailer is over 10,000 you do need a class A CDL in that statement you are partially correct. The part you forgot though is the tow vehicle has to be rated for 26,001 pounds or more GVWR.
Therefore if I am driving a vehicle that has a GVWR of 26,000 pounds or less I do not need a CDL of any class even if I am towing a trailer that has a GVWR of 10,000 pounds or more.
As I stated earlier if I was to hitch my 10,400 GVWR trailer to my work truck then I would need a class A cdl because the work truck has a GVWR of 32,800. Being that my private truck has a GVWR of 11,000 I do not need a CDL even if my 10,400GVWR trailer is hitched to it.
So what are the laws in Texas?
1991 Ford PL Custom Ambulance Type III 7.3L Diesel. Photo Here Pioneer AM/FM/XM/CD Stereo. Code 3 lightbar, Whelen Strobes and flasher lights. Whelen flood lights on front, rear and sides. There bright enough to turn darkness into daylight. Siren with several tones plus electronic airhorn and PA. Custom 3" exhaust from manifolds back with a Gibson Superflow Muffler [img]/ubbthreads/images/graemlins/grin.gif[/img]. Dual alternators and dual sets of batteries. If I need a jumpstart all I do is push a button. On spot tire chains that install and de-install themselves at the flip of a switch. Also has air compressor on board along with suction unit and O2 system.
1972 Cadillac Hightop Ambulance by Superior Lucky if I get 10MPG
