Re: Which Fuel pump?
I've been using a SX Performance 18201 fuel pump for awhile now, with no problems. I use a heated in tank fuel pickup with a HIH heater and a temp sender just before the pump, after the engine is up to normal temp oil gets up to 180 degrees and stays there. The pump has no problem pushing hot oil at 80 psi.
2000 F350 SC 4X4 LB XLT 3.73LS DP-Tuner (Stock, 60Tow, 80Econo, 120 Race), ATS turbo housing W/Wicked Wheel, Banks BHA, DIY CCV re-rout, 203* T-stat, Sonnax/Tricum mod, DIY Tymar intake, Frantz Bypass Oil Filter, Autometer 4 Pillar Mount, Jeg's 4" Turbo Back Exhaust, SUVlights harness, Sylvania Silverstar 9007, 45 Gallon Excursion fuel tank, 26 gallon heated WVO tank, Lariat Wheels, BFG A/T 285/75/16's, Snugtop extra vision and Powered by Vegetable Oil!!!
90K miles on WVO and counting
socaps
