Diesel Forum - TheDieselStop.com - View Single Post - Which Fuel pump?
Old 04-03-2006, 09:54 AM   #7 (permalink)
scottefontay
Re: Which Fuel pump?
I just spoke with a Tech at SX performance about the SX Performance 18201 , which has been replaced with by the 18203. He said that as long as the oil is loose there should be no percieved problems using it with vegetable oil. Generally the only problems they see are associated with the use of newer ultra low sulphur fuel blends that wear out the brushes due to reduced lubricity. I think I may give it a try.
JoJon, how long have you been using your 18201?
2000 F-250 Super Cab Longbed
Bright red, they call me "Clifford"
scottefontay is offline   Reply With Quote
