Re: Where to grab coolant from engine
Todd
I get mine from the port on the rear of the drivers side head. I have an OBS truck so I can reach it from above or below, but on a SD I think you'd have to get to it from below. It is slightly higher and to the rear of the exhaust manifold and is a 1/2 npt plug with a 3/8 recessed square drive that takes a 3/8 extension to remove.
Both heads are the same so if you look at where the heater gets its supply from on the pass side and then visualize it turned 180º you will know where to look for the plug on the drivers side.
Rodney#33
96 F250 XLT, RC, 4X4, 3.55's. 86 Kingpin D60, Sixpak of TW's tunes, DI Mini-Me's, H2E, Stealth Oil, BDP Fuel/twin SD pumps, ARP headstuds, DI pushrods, John Wood Trans, JoeServo IDM, 6.0 intercooler, Windstar fans, SD dual tensioner pulley, 4" TuffCountry lift, 35" BFG AT's, Centramatics, MileMarker hubs, Westach gauges, Fumoto valve, Amsoil bypass, Stancor 586-902, Aeroturbine 4040 /4" stacks, SD seats, PA 2818, 203º t'stat, vented filler necks, a/c mod, custom desert pinstripes,,,,,,,,,
2000 3500 SLT QC 24V 4x4 DRW NV5600 mostly stock
Arizona Powerstroke Group
