Diesel Forum - TheDieselStop.com - View Single Post - Why not run unwashed bio?
Old 04-16-2006, 11:14 PM   #3 (permalink)
dssamp
Re: Why not run unwashed bio?
I also wash BUT Not sure of such a fast answer.......:
Where does all that Mentanol go? Evaporates when you dry the biod
Where does all the excess Lye go? To the bottom with the glyc
Where does the water that may have been in the WVO go? Evaporates when you dry.
Through the injection system if you do not wash it! NOT!
And heaven forbid you did not let all the glycerol settle out. When then let it settle & dry it.
There are a LOT of people running without washing...and have put tons of miles on. This isn't the only forum with info...if you want to run without washing do some searches and make up your own mind.
David
[img]/ubbthreads/images/graemlins/smokin.gif[/img]
08 F350 King Ranch LB, SRW, Black&Gold/373 gears, 20" tires, everything but a backup camera. Adding Firestone air bags & Tork Lift tie downs. Still Stock & liking it.
01 F350 4x4 off road pkg, auto w/373 gears, Lariet SRW Midnite blue. Dueler AT tires, 4 inch HOG SS exhaust with 5 1/2 " tip. Rancho 9000 shocks, Firestone Air Bags, HOG guages, Lance 1130 camper and 19' Lowe Roughneck
dssamp is offline   Reply With Quote
